Smoky
Under the bottom of coolant recovery tank is a hose that leads to a Y fitting that is also hooked to what appear to be a heater hose. I have a constant drip there that has leaked out abot 1.5 gallons over 3K miles.
I put a new clamp on the heater hose where it joins into the Y fitting which is where the leak appeared to be. It still leaks there. Can the Y fitting be cracked as there is not a clamp on the hose coming from the recovery at the Y fitting?
