Hey y'all, some questions for consideration:
My truck ('02 PSD CC 4wd) got 20+mpg on a run to Illinois last week, and I was happy to stop by Indy and pickup a 6-pack of fuel filters from the Wabash shop, and a shiny new spare CMP). I also picked up some coolant test strips, and upon returning home crawled under to a) loosen the CMP bolt, b) get some coolant from the radiator drain and c) admire the view.
I noticed a big drop of coolant hanging off the bottom pulley and more up above it. The coolant SCA(?) checked out at around 2.1 which means add more additive (added 1 pint last month). I'm thinking with 58k miles on original (green) coolant that it is long overdue for a change (bought it used, assuming it wasn't changed).
Sorry for the long wind , here's the q's:
1. should I worry 'bout that leak, and if so, advice on diagnosing (water pump I assume...is that a warranty item?). Replacing all that coolant just to tear into a water pump seems short-sighted, eh? OEM vs other water pumps, advice?
2. would you go with more green coolant, or swap to yellow, or other?
3. after this long period (58k over 4 yr) is it still advisable to put on a coolant filter?
Thanks in advance for any thoughts or ideas. Appreciate it!
