Is EGT available on that unit Bill?
dont know how it would provide that, since its getting all its data
from the OBDII port...and theres no factory pyro
The below are some that are available but unsure of the years covered.I'll add the top section in Saturday morning to see what works.Is EGT available on that unit Bill?
The main numbers I want is transmission,rpm,volts,mph and a few others. The plug coming off the port is a right angle style connector. I had it plugged in for a few days and really didn't notice it but then again I wasnt looking for itFORD "CAN" applies to all 6.0L engines (2003+) as well as
current model (6.4L) engines.
As CHP points out...there is not EGT, since there is
not EGT Pyro/Probe (from the factory).
This gauge is really only reading SOME of the data that is available
to MOST OBDII data port....as such it can read engine codes and
reset them (but it doesnt provide any real diagnostic data or tests)
Im considering it just for the voltage readings (which btw you can
get from thru the odometer).
Im wonder how VISIBLE the plug is coming out of the OBDII port
under the dash...i wish theyd designed this a little different so that
you didnt have to have this plug & cable sticking out under the dash all the time.
That is the reason I do not leave my SCT hooked up. I mentioned it awhile back but I cant believe in this day and age that we arent wireless with devices such as these.
