Woke up to a nice temp this morning of 17 degrees. Fired the truck up and thought I had lost 5 cylinders! Never heard such chugging. I have read before that FOMOCO has already installed a block heater. My ???? is where is the plug located?
CHPMustang said:The cord is installed on Powerstrokes originally sold in the following states: Alaska, Colorado, Iowa, Maine, Minnesota, Missouri, North & South Dakota, and Wyoming.
Sometimes the cord is zip tied up pretty high you may have to remove the grille to access it from the top.
Additional areas to check;
Pass side in bumper below radiator.
Just curbside of the passenger side towhook.
Possibly between radiator and grill/bumper by passenger side foglight(if equipped)
Put your hand in through the passenger side tow hook hole in the bumper. Feel/look to the right and up a bit. There is a black ribbed wire loom sheath folded over on itself and tied with a black tie-wrap. The plug itself has a black plastic cover snapped on it, which has a restraining strap that goes around the wire loom. If you cut the tie-wrap, you can bring the plug down to the level of the hole to get at it.
Bill
Dave, did your 04 come with the cord?DaveBen said:Everyone has a block heater, but not everyone has the cord. If you have a '05 or newer truck you probably do not have the cord unless you live in the states that CHPMustang listed.
Boatfix has em for $15 a popbama-six-gun said:i have a ? for ya dave, or anyone else. now that i know i have the cord, i have seen some trucks that had plug-in receptacle that they put in their front bumpers to elliminate the cord from just hangin around.
where can i get this application for my truck?
well, i did a search on here and found it, just ordered one for my truck!
