Cold
Campby9
Duluth, MN
any idea why my truck runs like crap when it sits for a day or 2. after 10-20 min warmup its good but seems to smoke alot and run bad. any ideas would be a great help. its a 05 f350 6.0l. 80k miles.
thanks
Glow plugs will cause smoke on a cold start. It will run crappy until it warms up. Diesels don't like to be run cold, they don't make a whole lot of power when cold. Let it warm up before you call on it to do some hard work.
DR.Diesel
marlow ok
sticking/varnished fuel injectors will cause a rough idle and then smooth up when they warm up.the early trucks ford designed a reflash to help improve the cold start.the rough idle statagy was designed for trucks that missed at 60 degrees and below .
hondo1312
Wichita, KS
I have an 05 F-350 that was recently updated so the injectors all pulse after the truck is shut down, draining the fuel out of them. You can hear a real quick ticking sound for a split second if you pay attention. This supposedly helps with cold starts.
It's supposed to be a factory reprogram from Ford.
ckamp52
ckamp52
italy,tx and stephenville
haha yeah i bet its a tad cooler there...i was just wondering because i spent a few months up there last winter on a job and it was like below zero everymorning so of course this activity should be expected i nknow thats to the extremes but>>>>
scottu5
