Cold weather issue
san-man
BAD FKR
Minot at the moment
I do not know if the weather has anything to do with it but he it goes.
I was on my way to work and about 3 miles away from the main gate (military). My truck started to slow down. I was going 55mph due to snow and ice on the road. The truck slowed to about 25-30mph. As I was making to turn to the main gate. My truck died, sat there for a minute trying to think of what it could be. Originally I was thinking it was gelled but I have never had an issue with the Amsoil cold flow (an anti-gel additive) before so at that moment I was puzzled. After about 5 minutes I decided to try and start the truck and she started right up. The truck acted like it had no problems after that. I also notice that the check engine light did not come on and I still have to drive 13 miles home. The current temperature is -15.
Just curious on what the problem could be?
Any help would be appreciated,
Carlos
Smoky
Mississippi State
......... The current temperature is -15.
Carlos
I believe -15 is pretty close to the bottom limit for your anti-gel. See Below.
Superior Cold Filter Plugging Point Depression
As the temperature drops, the wax naturally found in diesel fuel begins to form crystals. The point at which wax crystals form is known as the cloud point. These wax crystals eventually clog the fuel filter and starve the engine of fuel, preventing it from starting. While low quality fuels may form wax crystals in temperatures as warm as 40ºF (4ºC), most fuels have a cloud point near 32ºF (0ºC). The point at which the crystals clog the fuel filter is known as the cold filter plugging point (CFPP). AMSOIL Cold Flow Improver lowers the CFPP by as much as 34ºF (19ºC) in ULSD.
san-man
BAD FKR
Minot at the moment
I guess since now that I travel further (I used to live on base). I really did not have that far to go. I guess that is why I did not notice it in years past.
Curious, if there is something that can protect to about -30. It does happen to get that cold and sometimes colder. With the wife's car in the shop, right now this is the only vehicle that runs at the moment.
Smoky
Mississippi State
san-man
BAD FKR
Minot at the moment
Looks like I will be buying the fuel filter heater in the morning. Just trying to figure out whether to buy the 50 watt or the 100 watt one.
............. and that's for your help. I really appreciate it.
Dogman
tampa,FL
The 6.0 do have a fuel heater already in line but it only works with the truck running. Check your relays, I think it 303 or 302. Check your owner book for the relay number.
I agree with what's been said.. that sounds like fuel gelling.. and in Minot, I'd expect it.
F350CCFX4
Smokin Bye
IA
That is a great base. Use to fill up gallon jugs with Tranny fluid and toss them on the runway so when the plows came through they swore they hit something. That has been almost 20 years ago now.
Had the fuel pump turn on and it wouldn't shut off up there. Couple kicks to the tank and all was well.
san-man
BAD FKR
Minot at the moment
scottu5
