Cold start
Down&Dirty Racin
GA
When i crank my truck up in the mornings when its cold it runs ruff like it has a big cam in it somtimes it will shut off it also blows blue smoke when it does it but it will only last a min or so also have oil leaking from transmission pan. Any help to my Questions would be helpfull
JRJ04
Houston, TX
If it goes away after a few min, that to me would sound like your glowplug(s) are bad.
For the oil leak...are you sure its coming from the transmission pan itself and not dripping down from somewhere above? That area is a common place for it to leak down onto and become visible. Is it engine oil or transmission fluid you are seeing?
iracemine
black and tan
Cheese Curtain
do a search for glow plug relay test. for your hard starts
and do a search for valley oil leak. for fixing your oil leak
and so a search for ccv mod. for preventing future oil leaks
