Codes dont understand them
budtoh3zo
Little Smoky, Ab, Canada
I got 2 codes P0297 i cant find it and P0560 System Voltage Malfunction i dont get this one im always between 11.8V shut off and 13.1V on help, thanks
P0297 is a Vehicle overspeed condition . It is connected with the injection system. This means that you overspeeded the engine and the injectors shut off (defueling). P0560 is a charging system failure. Your voltage should not drop below about 12.4 volts.
Northeast Texas
echo dave
you got an electrical issue
you should have more than 13.1 volts running even at 2500
drop into autozone or one of them places and let em do the half baked load test it will help isolate teh issue
whether you got a shorted cell in the battery or the alt is going south, loose connections, bad ground, etc
11 volts at rest indicates a load.
overspeed the engine..... only can solve that?
hope we helped some
Kleetus
Butler PA
I'm wondering if the two aren't related... Low voltage causing a sensor to give false or irroneous readings.
budtoh3zo
Okay i figgered it out, Its my outlook monitor when i hit the EGT Defuel point is when it throw them at the same time so thats the P0297 Defuel code. the other i dont know about i think just gets trown in.
TacoCat
