Help Needed code 31 rear axle non LS
Fine69
Cranberry Twp,PA
By 'open' in the front you mean they (Ford) doesn't put any limited slip in the front diff.? My education has been sadly neglected
Thanks for the suggestions, I'll see what there is around locally (not much) and then order something out of the good ol' USA
Correct, the front does not have limited slip.
Zmann ARGH
AZ
Lock-Right locker for Ford 10.25", two pinion only. This is a mechanically-operated unit which locks when power is applied, giving full power to both tires, and unlocks when you let off the gas. The Lock-Right unit installs into a standard open carrier, offering a lower cost alternative to full-carrier lockers. These units are not recommended for applications with high horsepower or large tires.
Pm_guru
