Question Code 108 ECM BP
mspainting
Painting The Town
Little Rock, Arkansas
Transmission is shifting real hard, rased the rpms like the torque converters is not engaging, trans fluid presure real high ?????:dunno:dunno
Hmm you're missing a few digits the error codes from your truck should be 5 digits
See the wiki article here for more information on the error codes and what they mean.
If it is P0108 then I would guess that you over boosted your truck which will trigger a limp home mode of hard shifts etc. Turning the truck off should reset the code. IIRC it is triggered at 25 or 28 psi. This also triggers defueling.
mspainting
Painting The Town
well the Transmission shop gave me those says he is not sure but he has more tests to run & he replced the wires to the trans & the plug he said 3 wires had been melted together. & the shift selonoid code & he is on the 3rd 1, & can't find anything wrong with them. The code i was refering to he said was a burromick presure senser on the board since it is a 2000 model
FlorWhitfe
