Clutch Replacement
bbressler
Happy, TX
Tried that....took out the 10K, still rough. This is rougher than normal...
strokin'_tatsch
death row inmate #7
Austin, Texas
does it do it cold? could be an ipr issue. like i said, my ipr o-rings went out so a friend of mine that works at ford gave me a used ipr that was still good that i swapped in it and it lopes now when it's warmed up a little bit. pull the codes and see if you have oil codes?
how do you like that clutch btw?
bbressler
Happy, TX
I think it's my fuel pump. Been doing a bit of diagnostics on it...cracked a return line, it doesn't pump anything back there. Will be replacing that next week.
So far, my clutch has gone about a quarter-mile. Truck died after putting it in, so I haven't had a good chance to test it out.
Shutting off the truck sure sounds better. My gear roll-over noise is pretty quite.
strokin'_tatsch
death row inmate #7
Austin, Texas
wow, my gear rollover is rediculous. i guess yours is quiet b/c you got a stock replacement.. i have to replace my fuel pump one of these days too. maybe wednesday.. or next wednesday... egh.. i will get to it one day. LoL:rant
let us know how it does when you fix the return line
