Rio_Grande
Hello gentelmen.
I have had a few pinion bearings go out in other vehicles and there was no doubt they were going out. Leaky pinion seal excessive heat after driving and vibration.
This last 2 or so weeks on my 99 psd I have been noticing what i though may be a wheelbearing in the rear going bad. Little nooise and vibration at 50-60 mph, not much else anywhere else. I checked the outer bearings for play and found none. I noticed that my tiers were over due for a rotation and sent her in for my 6.00 rotation and balance.
When my wife went back to pick the truck up the fella at the shop told her the truck has a serious issue with the rear pinion bearing. That is was so bad that you could see it raising and lowering a half inch when they were messing with the tires.
Supprised but willing to accept it if true I crawled under the truck today and found no signs of this being true. The only thing I havent done yet is lift the back end and get all bind out of the system.
I have checked the slop in the drive shaft and found it less than 1/16 of a rotation, I can press up and down in and out and there is no movement of the pinion shaft other than normal rotation. I figure tomorrow I will get the weight off of the tires and get out the dial indicator if need be.
As usual, this truck cannot be down for any extended period of time but I am not gonna try these my self.
Is there any other for sure way to check the pinion bearings to determine if they are bad?
thanks
thanks
