uhhmmm
i would bet your water pump is the culprit, even with the gold coolant they still fail, whats your mileage.
the gold does not need to be ph checked, just flush it and change it every 100k miles if i remeber right.
plus new hoses and belts...
but the waterpumps for some reason like to eat the bearing seals and drip drip drip weeep weeep LEAK
7.3 are prone to cavitation, thats another reason they went with the gold coolant and the sca additives to help reduce the damage caused by the bubble
if your unsure your strength and it is a mixture of old and new, your setting youself up for some issues.
you may need to bite the bullet. if the water pump has over 50k on it, put on a new one, flush the system and refill with correct gold extended coolant.
