The check engine light came on immediately at start up. I had it checked at Advance and they read the following code:
P2285 - Injector Control Pressure Sensor Circuit Low
Can someone shed some light on what this means? I have about 3k on fuel filters and oil change. I am using Motorcraft fuel and oil filters and Rotella oil. Is there a common problem that can cause this? I don't feel a performance difference, but the injectors are very quiet immediately on start up and the normal injector chatter starts in after a couple of seconds.
