GDS said just that when I called them today. They also say they have sold thousands of these springs without issue. Perhaps the leakage problems that are being refered to are from high pressure aftermarket pumps that get turned up to 100+psig in addition to the greater volume that those pumps are capable of. I'm going to give this spring a try. I haven't heard of this as a problem here on this site and I really want to check out the difference that it makes w/my stock pump. Perhaps my stock pump is only capable of 75psig; we'll see.
I will practically guarantee you that your stock pump can get to 100 psig. That is the design. If it can not produce that pressure, your pump is failing or there is a restriction.
It comes down to believeing them or believing Ford. I will repeat - Ford
specifically states in literature that risking injector o-ring failure can begin at 75 psig. There is no question as to the meaning of their statement - it is specific.
IMO - The wise person will be conservative. Running OVER 60 psig will get you absolutely NO benefit (this is not a 7.3L diesel). The only thing you need is to ALWAYS keep the pressure over 45 psig since this is the leading cause of injector damage (low fuel pressure - another Ford statistic). More pressure does NO good. You want enough pressure so that at WOT you will not drop below 45 psig.
Do what you want, but it is an expensive risk.
