Metalhead
I'm pretty sure I've narrowed down the vibration and chatter I've been feeling to my rear axle, with the trak lok posi. I've got another thread on here where I was asking about how a slipping tranny felt. The more I've been feeling this, the less I think it's tranny, since take-off, shift and power all feels the same.
I went to the walmart parking lot today to test out the symptoms, and it only happens when I back slowly when in a slight turn, same thing for pulling forward. It even happens when I'm rolling in neutral, while turning slowly. It never happens when moving straight. I came home, raised the left rear wheel off the ground and put the truck in N and engine off, and I can feel a good stick to the wheel when trying to turn it, with it eventually turning after I put enough force on it.
I've checked the fluid level in the rear axle, and it's right up to the check plug.
This chatter/vibration has been happening ever since two weeks ago, when I tried driving up a steep dirt hill in 2wd, spinning the right-rear well pretty good for about 3-4 seconds, before I kicked in 4x4.
Does the fluid go bad after awhile, causing this chatter? Or is this telling me I've got worn out clutches in the trak lok? Would a fresh fluid change fix this instead? I've almost had the truck for 30,000 miles now... Not sure if it was ever changed before...
