Changing Valve Cover Gasket
LonestarBronco
Yuma, AZ
Any rods of wisdom, tips, or things to look out for? My driver's side valve cover is leaking a fair amount of oil from the rear and I plane to replace the gasket this weekend.
majek5
Northern Il
Pretty much "plug and play" just take off all the stuff around it and replace it. Torque them down accordingly, good to go.
a double jointed monkey with small hands would be helpful
in all seriousness 1/4" ratchet is your friend. keep in mind that these gaskets seal by o-ring so you might just have some that worked loose and do not need to replace the whole gasket.
trickyricky23r
