And on the fuel filter note... Thank you Jvencius for your help last Wed night chat
. I changed the filter to a wix and my old cap and still it was leaking about a teaspon daily so I attempted to tighten up every fuel line/connection I could find around the separator bowl and overtightened the regulator line to the point it snapped! At 94K miles and 5 months before the 5yr/100k ran out on the fuel system the Dealer warrantied it!!! that's one for them, but the retarded part is the cap is a removeable piece with easy access and simplicity. So why does the dealer not just carry an improved cap piece to replace? They instead are replacing the entire High pressure pump and separator for a 100 bucks. No wonder they're closing plant with that kind of management. And they are also replacing the return fuel line because the can't remove the left over tip from the inside of the nut. Down side is I'm out of my X for 4 days
, up side $100 vs $1200... HMMMM?:ZigBang:
