Cannon
Anyone know if the Catalytic converters all bolt up the same on the 6.0l trucks? 3.5" Slip joint on the muffler and 2 bolt ball socket flange on the downpipe?
One would believe so. Not completely positive. Why?
I searched all over the net and could not find anyone that makes a simple cat delete/off road pipe. It takes 5 minutes to take it off and would be nice if someone made a factory fit pipe to go in its place. Not everyone wants to put full turbo back exhausts on their trucks, apparently most companies sell the downpipe and the cat delete pipe together. I think I might just build one out of all 304 stainless and have it a 5 minute direct install. It just would be nice to know if what I make will fit all 6.0l trucks.
This is the part description off the site.....
The muffler delete pipe doesnt have the 45 degree bend or the ball socket. I know I could just hack the cat directly after the bend and put a 3.5" pipe in place of it. Then connect one end with a band clamp and the other will go into the slip joint. If I found out that every 6.0l truck had the exact same fitment of the cat I would make factory exhaust style cat deletes. Those would be for the people that dont want to put a big exhaust on but would like to VERY easily remove the most restrictive part of the system and be able to put it back on if needed.
