Cat vs No Cat
Zookie400
I WANNA GO FAST
wallingford, CT
test pipe (cat eliminator pipe) is definatly the way to go. gutting it is easy, but then you dont have anything for backup in case you fail emmissions.
sawed off
Party like a rockstar
EGF MN
So can you just get the pipe from mbrp or somethin for the stock exhaust? I don't want to gut my cat.
kingkevindavid
Middleboro, Ma
MBRP Sells the pipe you need. besides being an extremely expensive item to destroy, gutting the cat causes turbulence in the exhaust.
jasonfrenchsr
THE BOSS 6.0
mcgehee ar
egr
just wondreing if anyone has done the egr block off coolent kit on the 6.0 ? i hear this would have saved some blown head gaskets when adding pwr mods. like bullydog, i know two guys that done just that and the both had to replace there engiens! i hear this really works? testing the waters.
LowSpoolHighFuel
Gloucester/VA/East
Straight pipe all the way!! It sounds like a jet engine when the turbo is spooling and i also notices a small mpg increase, not much but every bit counts.
