Cat/Ford
Dogman
tampa,FL
A buddy emailed me info on the Cat/Ford set up 3.0,V-6 HSDI (High Speed Direct Inj.) This motor will before the F-150, using twin turbochargers with wastegates. This motor may be used in the Toyota Tundra, Nissan Titan and Lincoln town cars.
HP :170 at 4000 to 4500 rpm
torque: 296 at 2000 to 2500 rpm
97powerstroker
north port,fl
ive heard the upcoming diesels for the big 3 half tons are gonna be puttin out over 300hp and over 500ft lbs of tq,so ill be pullin up to 150's and gettin out pulled,technology sucks.
Zookie400
I WANNA GO FAST
wallingford, CT
Those numbers fail to impress me for a 1/2 ton p/u.
what if those numbers start at idle, and go up to about 4500 rpms? or what if they bolt it to a constantly variable transmission? i bet they have something to give it that "edge".
Autoweek said:
AutoWeek is reporting that Ford will allegedly be putting a supercharged 4.4L diesel V8 engine in the F-150 for 2009. Expect it to have around 330 horsepower and 520 lb-ft of torque! GM & Dodge are also planning on putting diesel engines in 1/2 ton trucks, but Ford is expected to be the first to actually produce such a truck. The 4.4-liter engine is a larger version of the 3.6-liter turbocharged V-8 used in European market Land Rover Range Rovers.
I have heard 330 hp. :sweet
Dogman
tampa,FL
There most likely starting numbers, there not going to tell you anything until they start building the truck for the masses.
Zookie400
I WANNA GO FAST
wallingford, CT
and thats the truth! i have heard so many rumors for our new product lines when they are in the design stages, and when the fianl product rolls out of the factory its nothing like anything you read in the magazines, or heard through the grapevine.
i also heard 330, i guess we will all need to stay tuned...?
what will they call it? powerbore? power...port? or perhaps "the cats ass"?
170 HP and less than 300 ft lbs will fail to impress me at any RPM if that is the PEAK horse and PEAK tq that the engine is capable of that you intend to stick in a 1/2 ton p/u with the towing and load capabilities that we demand today. Now if it was going in say an Escort or a Focus we might be talking.;)
Dogman
tampa,FL
Ford has a big market in small diesel motors in the AU or down under. So something fun should come from this in time.:sweet
pete37922
JERZY
i thought they already had a smaller diesel out...seen them in small cabovers !!!
scottu5
