Cat delete?
250SOL
Alabaster, Alabama
I was woundering if anyone is using the MBRP delete pipe on their truck? Will it bolt to the factory down pipe? I have installed a flopro cat back on my truck so I have 4" exhaust now and just woundering if the delete pipe would fit my factory down pipe. Thanks for any help. I was goin to ask this before I ordered it.
HeavyAssault
King William, VA
The OEM pipe has a different style flange so it may not be a perfect fit. Why not add the MBRP 3.5" downpipe? Does the FloPro slip fit the cat now?
250SOL
Alabaster, Alabama
The flowpro does fit on the cat pipe then goes to 4". I can't tell if the front down pipe is factory or not. The down pipe looks bigger in diamiter than the front pipe to the converter. The flange on the delete pipe looks the same as the factory pipe it says in description that it wont hook to factory exhaust. The MBRP kit from the turbo back is slip joints. so that is why I didn't know if the delete pipe would work with the factory down pipe.
psycoticredneck
Brookville Ohio
It should work. The aftermarkets turbo back systems that retain the factory cat have flanges to meet up with the cat therfore a cat delete pipe should have the same flanges and would in theory meet up with a oem downpipe. I didn't have to deal with this issue since i installed MBRP's "Off Road" turbo back system which permanantly does away with the cat and all the pipes are slip fit all the way to the polished tip
TacoCat
