Carrier Bearing and U joint Install Questions
bserventi
Queen Creek, AZ
I need to replace the carrier bearing on my rear driveshaft. While I had it apart I was also going to replace the U joints as well. I'm not worried about swaping the U joints, I've done the front axle U joints with out problems, I would imagine the rears would be the same.
My concern is with the carrier bearing. Is it straight forward, or does it need to be pressed on with special tools?
Thanks
Bill
The race is pressed in, but you can hammer it in if you don't hit it too hard. You will have to re-shim for the proper clearances for the turning torque of the shaft. I don't know the spec.
bserventi PM me an email address and the type of axle housing that you have (Dana or Ford axle) and I can send you a portion of the manual on it.
Dave :)
By the way, you have blocked incoming PM (Private Messages) and I can't sent you a PM. Unblock your PM's.
bserventi
Queen Creek, AZ
Allright i fixed my PM's, it should be able to be sent now.
I dont know if its a dana axle or a ford axle?
Look on your drivers door post for the Vehicle ID Tag. Look for the axle code and post it here.
Not what I thought it was; the code that is. It doesn't tell what differential you have, just the ratio and open/limited slip. You have a 3.73 with limited slip differential. Give me an email address and I will send you what I have.
bserventi
Queen Creek, AZ
Dave,
Thanks for the PDF file, but thats not the part I am trying to fix. I am trying to replace the driveshaft carrier bearing, I guess it is also called the support bearing. It is about 2-3 feet behind the transfer case on the main drivline going into the rear diff.
I did not understand that. I will look later when I turn on that machine again. I will send what I can find.
scottu5
