Can I fit 35's with just a leveling kit?
You upgrade your trac bar as well Don? Those puppies take a few hits with a mallet to get back in the bracket.
godofdew11
where is the bus today?
nah stock with stock trac bar but kit came with a new trac bar bracket to lower it and in theory keep in place, tightened the bolts in a different order and it went alot easier, so its all together just my steering wheel is 90 degrees off, sure does look purdy, on my one trip up and down our deadend road to make sure nothing fell off it seemed to ride the same? but ill let you know more later. def would be ALOT easier with a real lift not trying to do with jackstands and pump jacks on a gravel driveway.
My stock trac bar rubber bushings went bad and upgraded to a adjustable model from Edge which came with polyurethane bushings,the axle lines up straight as an arrow,makes the alignment shop's job a ton easier:sweet
Something to look at for another upgrade in the future;)
trickyricky23r
