twt
Camshaft Timing???
Has anyone ever had a problem with the gear on the camshaft moving? I have heard that the pulley is pressed on the shaft ( Dave at Swamps ) & it can loose it`s fit & start moving front to back , (floating -Jodey @ DP ). If you have had this problem what was the fix??? I have a miss that is bugging me , I have changed -CPS, injectors,wiring,torque converter, IDM. Lots of $$ chasing this problem Help & thanks to all that read.
