Buzz under dash help!!!!
airdrew99
Living for Him
Brandon, MS
Check out some of my other postings on these threads:
http://www.superdutydiesel.com/forums/99-7-3l-powerstroke-engine-drivetrain/27296-where-buy-fuse-block.html
http://www.superdutydiesel.com/forums/99-7-3l-powerstroke-engine-drivetrain/27541-windshield-leak.html
I found water leaking down my driver's side A-pillar and dripping directly onto my fusebox. This caused tons of corrosion inside the fusebox. I disassembled it (layer by layer) and cleaned all the corrosion of with a small bead blaster. I reassembled it and everything works great. The corrosion was allowing current to pass. I really found this problem once I saw this happening every time it rained. Shoot me a PM if you have any questions.
Drew
BaronPFC
Noblesville, IN
wow, that helps a lot thanks airdrew99.
I do have a small crack at the top of my windshield by the A-pillar but I didn't know any water was entering. I hope I can save my fuse block like you did if thats the case.
