NASCAR Mike
I am trying to decide which way to monitor things on my 05 Excursion with 6.0. Current mods are:
DP Custom Tune 80HP Economy Tune using SCT
MBRP 4" exhaust turbo back exhaust with cat delete
Accufab elbow
EGR delete
I want to monitor EGT temps, trans temp and boost pressure. If I buy the Bully Dog Watchdog it will run abpout $350 for the little computer and EGT pyrometer kit. WatchDog<sup>TM</sup> Multi-function Performance Gauge
If I buy the Auto Meter gauges for EGT, trans temp and boost pressure along with gauge pod it will run about $315.
The Watchdog would be easier to install, will show me EGT temps (with pyro kit I would need to install), trans temp and boost pressure and will also show me other things like water temp, battery voltage, oil temp, etc. The monitor uses the factory sensors to gather this information. My concern is how acurate are these factory sensors? The info they provide is only good if they are fairly accurate.
Auto Meter gauges are fairly accurate but the info is limited to what gauge you install.
Any advise pro or con for each would be helpful.
Accufab elbow
EGR delete
