kingkevindavid
My truck was starting and running all day, I went to start it to unhook the trailer I was using today at my shop and nothing but a single click and the gauges doing some funny stuff.
Started looking around, put a battery charger on it (no help). Had a guy
trying to help but as usual was more of a PITA than a help (you would have to know him)
I knew I had some corrosion on the battery cables so I started to clean them
up and I notice that the battery cable on the passenger side that goes down
to the starter is completely broken off!! It had corroded that bad!! it was
actually hard to notice the corrosion down there because it runs under the
negative cable.
Anyway I had a large eyelet hanging around that I crimped one for now. I was looking online and the only fix I could see so far is a complete positive battery cable system, from drivers to passenger side and down to the starter. It's quite pricey!
Anyone have this experince? If so how did you fix it? Seems there would be a replacement battery end that would crimp on like the broken on did instead of buying the whole system.
negative cable.
