Brake Controller wiring for 99 PSD
forumpete58
Kansas City, MO
Hey guys I've tried searching but can't seem to find if 99's have a factory port to plug in a brake controller wiring harness. Can someone tell me where I can find this in my truck?
Thanks!
trackspeeder
Stone Crusher
North Branford CT
Trailer tow was an option for 99 and 00 years XL and XLT models. Option on 01 and up XL models.
I don't see the connector in your photos.
newt92
Secor Illinois
DIESELSITE
Supporting Vendor
Cyrstal River, FL
You are absolutely correct! If you still have the harness in your glove box, all the trucks came with the harness that plugs directly into that port. ;tu
forumpete58
Kansas City, MO
Unfortunately I don’t still have the harness, but I bought one that I hope will fit from an auction for $8 shipped.
Thanks!
BOY.. That Bob (and Shirley)......!!! Where would we be without'm. ;tu ;tu
Red Monkey
Alabaster, AL
After everything is wired up you may want to check your under hood fuse box. After pluging my harness in and getting my box hooked up I had no power to the box. I needed to add a couple of fuses in order for everything to work correctly. I don't remember the numbers but they will be listed in your owners manual.
You know Ford sure made the brake box plug hard to get at. If they had put it on the drivers side if that brace it would a lot easier to access.
forumpete58
Kansas City, MO
"You know Ford sure made the brake box plug hard to get at. If they had put it on the drivers side if that brace it would a lot easier to access."
That's for sure, not the best planning.
Thanks!
FlorWhitfe
