dmcvey_1999
I am the proud owner of a 2006 F250 diesel Lariat model. I have put 46,000 miles on the truck and have been happy with the truck until now. While going to the movies Friday night I heard a grinding while stopping at a light. Saturday morning I went and bought brake pads assuming the 3 yr. 36,000 mile warranty was up. I took the right rear tire off and removed the caliper. The front of the brake pad (touching the front surface of the rotor) was fine and no grooves felt. When I removed the back brake pad I knew where the grinding was coming from. There are two cylinders within the caliper. One cylinder was a good inch distance out further than the other. This caused the back pad to be slanted and causing uneven wear on the brake pad. Well as you can imagine it ground about a .25 inch groove into the rotor. I have called around and nobody has a rotor including the Ford dealership. I called the dealership to order the rotor and caliper and after talking to the parts guy he stated he thought it should be under warranty. Come to find out Ford extended my bumper to bumper warranty to 72 months 60,000 miles. So now it is over at the dealership. A little concerned though because when I talked to the service writer he stated that if there is any aftermarket parts on the truck this will void the warranty. We shall see.
