boost sensor
06cumminspower
browns summit, nc
my powerstroke has a rubber hose running out of the passenger side intake runner and into a little box on the firewall with electrical connectors hooked up to it, i guess this is the boost sensor? Anyways the rubber hose is dry rotted and broke can i just block it off or do i need to run a new hose? i heard that the boost sensor would start to defuel it if it exceeds 25psi and i would like to put a programer on it and run more than 25psi that is why i was wondering if i could just block it off.
DOC-MX
FOREIGN MEMBER
Celaya, Gto, MX
Is the MAP sensor hose, you should repleace it, the truck needs it.
94f450sd
certified nutjob
plymouth,ma
replace it as was said the truck needs that sensor working to run correctly.our trucks dont defuel.we can run all the boost we want without defueling.
FlorWhitfe
