Boost Question
early 99 stroker
White Mt's NH
yes it is a common thing for the donuts to go bad..a lot of us went to bellowd up pipes that do not use the donuts...any soot is a signe of boost loss..the turbo needs that exhaust to spin the turbo....nic's,chips or dusted wheel is also a signe of bad boost...
dmd
Member
Double Oak, TX
A 2k stock will be max of 17lbs boost. As others have mentioned, they start making good power around 2000RPM so that is usually where I tow. I doubt I have ever had the engine above 2500 RPM. Even shifted out of OD it is still going about 60-65MPH when climbing.
You may have a hard time getting max boost without a trailer hooked up,m but you
should see more than 10psi
check to make sure that the wastegate is adjusted properly otherwise you are blowing boost off way too soon.
early 99 stroker
White Mt's NH
