whatabudro
Launched
- Joined
- Jun 12, 2005
- Messages
- 0
- Reaction score
- 0
Fire1 said:What pressure are you seeing on you boost guage at WOT in your highest chip setting?
If you are seeing above 20 or there abouts if I recall, the PCM will "De-fuel" the motor in an attempt to lower boost/power to protect the motor. So you will loose power. The boost relief valve "blows off" some of the boost to the Map sensor (not actually blowing off boost (air pressure) to the motor) to fool it and keep the engine from De-Fueling.
Hope that helped some.
Where do we find out what the programming is on the map sensor. If you are correct about 20lbs then I do need one. I have never had a CEL on my truck and I thought that was the main purpose of the relief valve. But if I'm defueling above 20lbs then I'm LOOSING horsepower and that sir is unacceptable.
