Question Blue spring
handyman34450
Inverness/Fl
Hello Diesel Fanatics, The 6.0 blue spring for the fuel regulator will work in a 7.3 fuel pressure regulator swap in??
No it won't work. They are totally different engines and fuel systems. Check out our 7.3 engine section and the 6.0 engine section.
Dave :)
JRNOLL
Bakersfield, Calif.
For my 7.3 ,I removed the fuel return restrictor and shimmed it with 4 washers that I cut to fit. This raises the pressure to the Injectors. It made a difference and did not increase the fuel usage.
Brad1103
