bradkline
I have a 2005 F250 with the 6.0 diesel and auto transmission. It has 115,000 miles on it. Only non-stock item is a SuperChips Flashpaq set on performance, which I took off tonight in case it was part of the problem. Over the last week it has been having blue smoke billow out of the exhaust at start up for about 10-15 seconds, then it goes away. It has also had two times where I let the glow plugs go until the light went off, then cranked for a good 10 seconds and it did not start. I turned off the key both times, immediately tried again and it fired right up. Starting to get a little cold here, been in the low 40's throughout the day, don't know if that has anything to do with it. I am new to diesel trucks. A few times have been after it sat for a while and a few have been when I start it within a few minutes of turning it off. Any input is appreciated!
