Bio-Diesel Fuel
skirk55
Newtown Pa. 18940
Can I run bio diesel fuel in my 2005 6.0? Everything that I read tells me yes but I want to ask questions and find out what happens!:confused:
Tx_Atty
Master Baiter
Fishin'
what happens - the valves dont cackle like with #2, your exhaust doesnt stink, you dont pollute the air (which would be an easy way to dodge emissions tests btw), and you clean out your system which could only help! If you can get a reliable and quality source then I say do it. I just started running it this last month and love it as most of the converts do. You are set and ready to use it as soon as you decide to.
with the ULSD you will need something to lube everything; bio is a great way to put lubrication back into your fuel.
Welcome to our site and stick around. Drop in a sig line and let us know what you have.
If your under warranty still, I think the owners manual says something like nothing higher than B5. Just something to think about to avoid down the road problems.
Skram
