biggest 7.3 lemon ever
machmedic
NC
If it seems to be "missing" I would also check the UVC harness plug. Had similar symptoms with CEL coming on and missing, connector was loose.
did you get a lot of oil coming out of the HPOP when you removed the IPR? Did you have to remove any of the fuel bowl assembly or did you just work around it?
Bad Night
Uniontown Ohio
Man I wish I knew about this site sooner . I got rid of a really nice 2000 Dually Diesel due to this same issue , dealer said they couldn't figure it out , I don't know enough about diesels so I traded it on an 08 with a V-10 . O -well .
FlorWhitfe
