Bigger injectors ?
lukecline
Kansas
u could also buy some hybrid injectors while still keeping your stock pump. would be good for 400 hp.
400 is all? i guess the dyno and track lied to me:eek::D
id go hybrids with small nozzles. when ya get more supporting mods go bigger nozzles and you have enough fuel for 500+ on a stock hpop.
CSIPSD
Bend, OR
Stage 2's will be fine with the factory HPOP, Hybrids will be fine with stock HPOP... dont let anyone tell you differant.
Stage 2's with good nozzles will put you at 400hp, Hybrids, depending on the Nozzles can go from 450-600...
Headstuds can be done with the motor in the truck. When people pull the cab to work on 6.0's its because, they have a lift, and its super easy. Cab can be off in about 45 minutes with two people.
NVJAY775
Gardnerville, Nevada
I was thinking of getting different injectors and heres my questions.
CSIPSD is right
Is it worth getting the stock ones modified?
No. Get new ones. Casserly's are great.
Will bigger injectors decrease MPG's?
CSIPSD
How big can I go without different HPOP or low pressure pump?
My 180cc AA codes run just fine.
Do I have to pull the cab?
CSIPSD
Just make sure your trans is done first. I only say this from experience.
