roosterdiesel
Earl needs B100
The factory hoses on the SDs have quick disconnects and I paid $120 for one hose at the dealer, it was made by aeroquip. The OBS's I believe don't have the QD fittings and have JIC connections on the hoses. Any competent hose shop should be able to make a new hose.
AA Sales on Polk St. here in Amarillo is an AeroQuip dealer. I use FluidLine(Parker dealer) on 10th Street for all my hoses. If you can take the hose off and show it to them it shouldn't be a problem, there may be a rating number to use for replacement hose. Also make sure they know the line can see 3000psi sustaine pressure on long WOT runs and is subject to pulse from the injection system. Also that the oil temp can be ~230 degrees F.
