I am playing around with my new truck and still on it's first tank of gas? It seems like my gas mileage is slightly better when I have the TOW/HAUL option turned on. I thought this just changed the shift points but it seems like it is doing a bit more, maybe changing something in the fuel system or injectors? You guys know much about using this option on the truck? Can you drive in this mode all the time? Maybe my larger/heavier tires and wheels make the tow/haul option a good choice for constant driving.
1st off its "fuel" not gas
2nd youre not gonna get better mpg in tow haul (it holds the shift points til considerably higher rpms and
it forces downshifting...which again will increase rpms...the higher your rpms & the longer you hold the rpms
higher the more fuel youll burn)
3rd the tow/haul doesnt change anything about the injections or fuel system, it will however change the
egr & vgt positioning to increase BACKPRESSURE.
Tow haul also <in my experiance> also tends to hold the converter lockup a TINY bit longer...reducing
<by a small amount> the locking/unlocking that can be encountered when cruising the interstate.
4th you CAN drive in the tow mode all the time...it wont necessarily be fun but you can do it.
what size are those tires...20's ? are they e-rated (check the sidewall)...there are plenty
on this forum w/ 20's and bigger...NO ONE has <ever> reported better mpg when running in
tow haul mode.
Don't take any mileage too seriously if you don't have at least 8,000 to 10,000 miles. These trucks take a while to break in.
dave fwiw hes got 39k+ on that truck.
