Question best oil for 2003 7.3
stroker21
Midland, TX
I run Delo 400 in the 97' OBS and Schaefers in the X. The reason....I was taught that once you run one in it to stick with it. I bought both of them used and just continued running what was already in them. Now if they have crappy oil in them, then definitely switch. Just my 2 cents.
Akpaul
Wasilla,Ak.
Here in Alaska I use Rotella 5w40 synthetic and dont have to plug in till it gets -25 Degrees. Sure is nice when I cant plug in and have been gone for 2 weeks at a time at sub zero weather to know the old girl(2000 F350) will fire right up. Wont do this with conventional oil.
Bbasso
Upstate S.C.
You guys say "often", But what's often?
3000, 5000, 7500, more?
My oil & filter is at 6000 and I plan on changing it this week
RON.B54
CLOVIS,NM
I use John Deere plus 50 diesel oil and fleetguard filters.The oil is $15 a gal from The Deere dealer. It needs to be change every 3000 ,but no more than 4000 mi.
I use Rotella 5W-40 and change the filter every 5,000 miles like clock work. 6000 is too long unless you are running Synthetic oil. Deere oil for $15 per pail is not syn oil.
6.0PSD777
Mass
I use Mobil Delvac 15W-40 and Motorcraft filters. I change the oil and filter every 3K mi and fuel filters every 6K.
RON.B54
CLOVIS,NM
No the Deere syn is $30 a gal that why I use the regular oil, and I work for John Deere.
carthage, IL USA
I have been running delvac 15 40for the last 25,000 miles. Can I switch and run 5 40 synthetic for the winter and go back to delvac after cold season is over.
