Beef Steak, Taters & Oynion
ramprat
USA
Knife
Fork
Napkin's
Phaser
Took one onion & cored it & then put butter & a bullion cube in the center & a tad more butter on the outside of it & double wrapped it in foil. Cut the other one into 4 pieces, butter & some Italian dressing & double wrapped it in foil.
Did the same thing with the taters, one with Italian dressing & butter & one with butter, salt & pepper & then double wrapped em in foil
Cooked em for 30 min on the grill & then turned up the heat for the ranch raised fresh killed Charbray/Angus steer
Steak has been dry aged for 2 weeks & then a little bit of kosher salt, some pepper & garlic on em and then a light coat of EVOO rubbed into both sides of the meat.
kbud14
I will never learn
Ohio
No steak is better than when you raise it yourself. Looks professional with the grill marks and all.
man that looks GREAT...what kinda grill are you using ?
heres a couple of my favorite accompaniments (that are EASY on
the grill).
Marinated Mushrooms.... 1/2 the mushrooms and put 'em on skewers
like you would shish kabobs....marinate 'em w/ italian salad dressing...
i prefer the "zesty" kind...and grill til tender.
Roasted Garlic....slice the top off a WHOLE BULB of Garlic...put a couple
of good size pats of butter on the top (where you slied the top off)...wrap
it in tin foil and roast it 30-40 min. on the grill...spoon (or pinch) the
butter soaked cloves outta the bulb and enjoy !
