Question Ball Joint
RGL38
Huntington, WV
Anyone know the torque of the nut on the lower ball joint on a 2000 F-250 2 wheel drive?
RLJR
mrpowerstrokeman
northwest
actually i did a set today at work :) lower bal joint is 99 lb-ft and then turn to the next slot for the cotter pin. and the upper pinch bolt is 60 lb-ft
RGL38
Huntington, WV
I am working on the truck as I as I have time. I will have the one side done tomorrow and the torque info is a time saver for me.
I thank you.
Ralph
Jinco
CO
Anyone reading this use caution when torquing the ball joints. It is ball joint manufacturer specific and must be done in sequentially in steps upper/lower.
I just tighten them to MFG specs in what ever sequence I choose. Works for me over 35 years.
RGL38
Huntington, WV
I got the job done. It wasn't bad at all. However about the torque I think the bottom has to be torqued first inorder to get the upper stud in position. Then tightnen the upper cinch bolt.
Jinco
CO
Per the Ford manuals, for my 2000 4x4, it goes like this.
1st- Bottom Joint: 35 lb/ft
2nd-Top Joint: 69 lb/ft
3rd and final- Bottom Joint: 150 lb/ft
This sequence is also correct for Moogs. Different ball joint manufacturer's may or may not have a specs different than this.
This IS important, but obviously some folks get away with doing it incorrectly. I have heard of others that had drivability issues when incorrectly torqued. Subsequent re-torquing solved their issues.
Its not like I would go back and take it apart and re-do it if I were you. I would imagine you will be fine.
