Apr 30, 2011 #21 M Mathew5973 SDD Junior Member Joined Apr 25, 2011 Messages 17 Reaction score 0 Location Bridgeport Ohio Will Will do Thanks again Let you know
Apr 30, 2011 #22 M Mathew5973 SDD Junior Member Joined Apr 25, 2011 Messages 17 Reaction score 0 Location Bridgeport Ohio K CPS Fine Found drivers sideto be running alot cooler Checking harness again and gasket
May 2, 2011 #23 Frankenstien Frankestien Joined May 27, 2005 Messages 607 Reaction score 0 Location South Prairie Wa. good place to start, you may need to shim your harness also to ensure it has a tight fit.
May 2, 2011 #24 M Mathew5973 SDD Junior Member Joined Apr 25, 2011 Messages 17 Reaction score 0 Location Bridgeport Ohio Shim? Harness seems to be a tight fit and no change in running condition. I have heard of wedgeing the harness to keep tight not shimming. Possibly the same thing the end result being keeping the harness secure and tight?
May 6, 2011 #25 Frankenstien Frankestien Joined May 27, 2005 Messages 607 Reaction score 0 Location South Prairie Wa. Yes Shim/Wedge, for the purpose of this thread, same thing.
May 6, 2011 #26 dpantazis #12 Joined Nov 8, 2005 Messages 1,852 Reaction score 0 Location under the cheddar curtain 2 quarters will work in a pinch too. like penny'g a door.
May 6, 2011 #27 M Mathew5973 SDD Junior Member Joined Apr 25, 2011 Messages 17 Reaction score 0 Location Bridgeport Ohio This step Ordered four more injectors valve cover and harness plus two external harness repair pigtails for the beast let you know the end result
