arrowstrap
BioMechanic
i had an oil leak on my rear axle seal that dipped on my brake drum. i replaced the seal.... i noticed oil saturating my front u-joint and most everything on the back side of the brake shield. i assumed it was another faulty seal... but there is no seal! i pulled the shaft out of the axle and it had a good amount of grime, sand and a few pine needles in it. the oil in the pumpkin looked clean... why is there no water/dirt seal between the axle and the shaft? seems dumb.
