Autoenginuity
JOAT said:
Actually, several Ford gas models back to 94 also had OBDII, but since the standard wasn't in effect till 96, they weren't all 100% compliant with the generic codes.
ACTUALLY the american car mfg's started doing it...it was the
federal gov. that FORCED others to do it (mostly the jap cars...at the time).
the problem was independant shops couldnt afford to buy a tool
for every dif. make/mfg...problem is the std. is NOW outdated &
so the mfg's have again taken to hiding data so you STILL have to
have special tools or software to get to the IMPORTANT data.
roosterdiesel
Earl needs B100
Amarillo,TX
Robert,
Your buddy;) at ITP has it for just under $350+ shipping. I got the domestic bundle for 500 bucks.
threejacks
South Central , KY
This is what's on their website:
Enhanced interface for Ford (EI01) 1994-2006
Although Ford does implement the largest subset of the OBDII standard compared to any other manufacturer, the typical vehicle only supports 20 - 40 sensors and is limited to emissions powertrain. Using the enhanced Ford interface, a typical Ford vehicle will support 200 - 300 sensors within half a dozen systems; that's essential systems like ABS, airbags, GEM, etc.
Our enhanced Ford interface coverage is only matched by factory tools; we have support for 2800+ sensors selected from all 68 systems. The Ford enhanced interface has support for Ford of Europe models such as Ka, Mondo, Galaxy, Fairlane, etc. Finally, our Ford enhanced has support for bi-directional commands and system level tests. With bi-directional controls, you will no longer be relegated to being just an observer in the operation of the vehicle--now you can take control of its operation.
System Tests:
KOEO
KOER
EVAP Bay Test
Service Bleed
Buzz Injector
Cylinder Contribution Test
Switch
Glow Plug Test
System Self-Test
Hi Speed Fan
Lo Speed Fan
KAM Reset
Power Seat Calibration Test
Audio Network Communication Test
Vehicle In-Motion IO Test
Front Wiper Self-Test
Rear Wiper Self-Test
All Outputs On/Off
I called them and was told sometimes it will not work with 1995 models and no explanation or excuse why. Has anyone used it on a 1995 and what were the results? If they are advertising it this way why are they telling me it does not always work on a 1995 PSD?
Trista8036
