anyone runnin 285 75 18s
missingsc331
new kent virginia
35's on 18's with leveling kit
jpringle83
WA
Isn't 285/75R18 one of the stock sizes? I'm pretty sure that's what was on my truck and the door jamb lists it if I remember correctly.:dunno
abitz
montreal quebec
hi , is that a 2" level kit , can you give me the exact tire size numbers , also how do you like the sct tune ? has the fuel milage increased ? sorry for all the questions I got 2008 and Its time for the tire upgrade but dont want to change the rims I wanted to know the bigest tire that can fit in there without going to a lift.
jpringle83
WA
With a 2" leveling kit (it's just a coil spacer) on your stock rims you should be able to fit a 35x12.50 with no problems. Aftermarket wheels are a different story if you go that route be prepared to unclip the fenderwell liner and move it back up against the firewall to keep it from rubbing. I think the 08s have bigger wheel wells too so I think you're in the clear running a leveler and a 35.:sweet
trickyricky23r
