Any transmission mechanics out there?
Having just finished doing my own transmission I can say that a trained eye is not really needed you just need to make sure that you have paitients.
As far as evaluating the hard parts for excessive wear the copper bushings/bearings are easy when the copper is gone then it's bad but those will all be included with a good rebuild kit. for the drums and real reusable hard parts general mechanics knowledge is good, there are some wavy spring units in there so that's normal but otherwise it's all how straight its it and are there any gashes and gouges which will be painfully obvious when you see them if they are there.
orion_134
Woodbridge, VA
This is what is included in the monster in a box kit from factorytech, it says nothing about bushings?
6 Low Reverse Steels
6 Low Reverse Frictions, Raybestos
1 Reverse Pressure Plate
6 Forward Steels, Koleen
6 Forward Frictions
1 Forward Tapered Pressure Plate
1 Forward U/S Pressure Plate
8 Direct Altos Reds
8 Direct Koleens
1 Direct Pressure Plate/Snap Ring
1 45 Element Sprag
1 Band, Intermediate
3 Intermediate Steels
3 Intermediate Blue Plate Specials
1 Overdrive Pressure Plate
4 Overdrive Steels, Koleen
4 Overdrive Frictions
1 Overdrive Select Snap Rings Set
1 Hardened Input Shaft
3 Coast Clutch Steels
3 Coast Clutch Frictions
1 Pump Boost Valve, Sonnax
1 Seal and Gasket Kit
Anything else I need? Going to reuse my brand new ftvb and the fttc
Jesse
Jesse
trackspeeder
Stone Crusher
North Branford CT
6 Forward Frictions
8 Direct Altos Reds
8 Direct Koleens
1 45 Element Sprag
Jesse
Jesse
Contact Racer X. He can set you up with a kit that will have all this stuff and some better stuff too.;tu
orion_134
Woodbridge, VA
I don't know that I need anything too crazy. The truck hardly tows any more than 10k and rarely gets hammered on except for the occasional on-ramp.
I ordered my pieces from Bill @ RacerX and got new bearings, think cam bearings except larger & smaller. While many looked almost new to me (I've rebuilt engines before so I have background on what worn bearings look like, not to mention I had new ones right there) there were some others that had notable wear and scoring in them but no wear on the shaft that rides in them. So they were replaced.
I'll say that in my searching I evaluated the kits from Suncoast, Factory Tech and RacerX and the idea of compiling what I needed from bulkpart.com. After having emailing all and calling and talking to Suncoast & RacerX I made my decision. The others don't have bad products by any means just the level of customer service was excellent and the phone and email help when I was actually doing the work was great.
