irish4x4
Mayor of Margaritaville
Love mine. Clean install, easy set-up, flawless performance so far. (3 years and counting)
I raced the guy i sold the tuner to He was on the highest setting on the edge and i was on about a 100 horse tune with my sct. Left him everytime. Called him on the phone asked if he wanted to pull over and i'd load a stronger tune and he just laughed at me. With the sct the custom tunes allow you to lock the tc on accel and decel. Jake brake tunes and most important is the turning off of the egr. Right now the edge is going for over $800. You can pick up a livewire with custom tunes for under $600. I didnt get mine with the egt sensor cause i already had a gauge pod cause i like the way they look.
The Edge highest setting is only a 100 horses unless u buy the code for the Juice ( that gives u 240 HP).
Thay work fine I just recently took mine off and went with a programer. The platinum controles alot more than the standared edge you just need to remember when you change power levels to take it easy at first so your transmission will relearn for the extra power.
I installed the Edge Juice only last weekend however I am waiting for the tranny learning period to run its course. From what I have experienced so far, it does provide a significant performance increase.
