Another question / problem
Tates97
Tate s97
Madison Ga
My ABS lght popped on tonite and the pedal will only go down about an inch but will still stop the truck. What might be wrong? Probably something elementary but I'm not aware of. Help? tate
clem
N.E.Ohio
Sounds like your vacume pump gave up.When mine went I only got the brake lite.
Tates97
Tate s97
Madison Ga
Now the ABS light is gone and the pedal depresses....only feels like the front brakes are working. What gives? Where is the vacuum pump? Thanks Tate
clem
N.E.Ohio
VP is under the AC compressor. take your fan belt loose and check the pully for slop and spin it , if there is no resistance prolly the diaphram is shot.
Tates97
Tate s97
Madison Ga
HAvent taken the time to take the belt loose. But the cruise works as do a/c. Will check for resistance in the am. Thanks tATE
since the air duct deflectors are vacuum controlled as well that's also a good determination of the vacuum pump but they don't take too much vacuum to operate so they only stop when the pump is completely shot.
